Wyze 6 router
Is there a way to reassign a device to a different router so I can balance the loads on each??
No…much requested feature.
You can do it the hard way; set it up again but use the other router’s WiFi.
Or switch to TP-Link where they have a feature called Connection Preference.
Any mesh router can do that. The OP didn’t say anything about a mesh.
Wyze 6 router is the subject. It is Mesh.
No not all WiFi6 routers are mesh routers.
I didn’t say that. I said Wyze Router 6 is Mesh. It’s the subject of the post.
Oh, I was looking at the post, not the subject. Have to start doing that.
Agreed, Works great on TP-link. :+1:
