I inserted it circuit side down and to the left. The flat side of the card was to the left of the slot (on the bottom of the camera). In Advanced Settings/Local Storage, no card is detected. Any suggestions or ideas?
Thanks for any help.
Same problem here. However when I remove the card and place in in a card reader there are video and configuration files on it. I’m using a WYZE card. I’ll be interested in the reply.
I would try to reseat the card using the end of a large paperclip to push it in until it clicks (but not too hard).
Had the same problem with two Wyze cards. Solved by reformating the cards with a computer. Don’t use the fast format option. Both cards work fine now.
