I have two Wyze Cams V2, I can’t get them to recognize the 32GB Samsung Mirco SD Card. I will hear the gong noise but the app it saying no sd card. IS the sd card suppose to fit all the way inside or does a little hang out? I can’t figure out why it’s not being recognized.
No, it shouldn’t hang out any. It needs to be inserted all the way in and usually you can feel it slighty click in place with your finger nail.
Edit: MicroSD Card
Thanks, i wasn’t sure because it wasn’t going in. I was able to use a object skinny enough to push it the rest of the way and now it is being recognized.
You are welcome. It can be difficult if you don’t have any finger nails. Using something small to push it in helps. Glad it is working now.
