I was wondering if anyone has had any luck finding the right kind of sticky tape replacement for the sensors?
I used whatever type of 3m like foam tape I had sitting around. They are fairly permenant but I don’t think I am gonna move them anytime soon.
If you’re near a Dollartree this has worked well for me.
https://www.dollartree.com/super-glue-pre-cut-foam-mounting-tape-6ft-rolls/247744
