Working cam v3 will suddenly say Ready to Connect. Why?
Suddenly cam v3 will say ready to connect and it must be setup again? What prompts this to happen?
Sounds as if the reset switch is shorting. Is it wet?
Dry as a bone and the reset switch isn’t jammed. I initially guessed that that was the case. Thanks.
I understand the V3 is pretty easy to open. You could do that, or just file a warranty return.
Have you found a fix for that?
I threw the camera away. It was obviously flawed.
