A wireless driveway / perimeter alarm consisting of 2 devices with 3 beams aimed at each other creating an invisible “trip wire”.
This would use a triple photoelectric beam sensor requiring all 3 “beams” to be crossed at the same time to be activated. This avoids false alarms; Only sending you an alert when something as large as a deer, person or car crosses between the 2 devices,
When the beams are crossed, a signal is sent to the receiver, and the receiver would communicate with the wyze cam to start recording and send a notification to your phone, and flash your wyze lights on your front porch and in your house to let you know something is on your property.
Requirements
- Triple beam sensor (to avoid false alarms)
- Solar (no wiring)
- Wireless zones (ability to add more sensors to work together to create a full perimeter watch around your house.
- ip67 Weatherproof
- 1 transmitter
- 1 receiver
- Rechargeable lithium ion battery
- Built-in solar panel
