I lost the tiny screw/bolt that holds my wireless doorbell to the mount. I was curious if anyone knew of a replacement that works for this?
In these situations I usually take it in to Home Depot or Lowes in a plastic ziplock bag (I always make sure it’s in the open and seen on camera as I enter) and you can take single bolts and find which one fits and then just buy that.
Oofff not sure if that’s one that can be found at a hardware store… coned head T8.
@alinajperez let me know if you don’t find a solution I have a broken Doorbell pro I have kept around, as a parts pack rat. I can probably salvage you one.
