Anyone know if there is a way to purchase a replacement mount? Specifically the one for double-sided tape. Long story short my apartment complex is repainting so I had to remove mine and it didn’t come off as nice as Id like. Chat support said to check with my local hardware store.
Was perusing topics and posts and saw that you hadn’t received any replies here.
Did you get this solved? Is the original mount broken or is it just an adhesive replacement issue?
I have found this product to be invaluable for replacing adhesive on my Wyze products. They sell it at the big box hardware stores:
