Hi All, first post. Just purchased the Doorbell Pro and the Cam 3 for my son’s college apartment for this fall. I purchased a doorbell anti-theft mount that said fits most doorbell cams but clearly it doesn’t fit the Wyze pro. It covers up the top sensor and half the ring button. Can’t find any that states it will fit this doorbell. Wyze should have their own for an option like Blink but maybe later. So has anybody been succesfull in finding one that fits?? Greatly apreciate any help. Thank You!!!
Nope, but you could post it on the #wishlist
Hello @paulsoffice.
If you do not find what you want in Esty or Thingiverse or Amazon.
Maybe @lachlan6 could print up one for you. He likes to solve problems of the kind you described.
Good luck.
Could you please post exactly what mount you purchased?
I wouldn’t mind making something but I don’t have the pro version of the doorbell so I wouldn’t be able to test anything I made. I have a pretty good size list of things I want to make already and the sales of my current designs are taking a decent amount of my time these days. I am trying to offload that burden so I can have more time to design new things again.
But more details would be helpful to maybe find something already existing or make something new.
Thanks all for yor replys. I purchased the DG-DIRECT bracket on Amazon. Said it fits most doorbells. Not even close with the Wyze Pro. I probably could cut it to make it work but that’s not going to look to good. This one totally covers the top motion sensor and half of the button for the bell. Wyze is pretty popular so I would think something out there should fit. Anybody know which doorbell may be simuliar?
Did you ever find something that would work I’m looking myself now? Thanks in advance for any help!
I bought the cheapest anti theft doorbell holder (which didn’t work) and asked my friend to use his 3D printer to print a back that would attach to the mount. It worked! If anyone is interested in more details, let me know!
I would like to get one if possible.
This is exactly what I need. I’ve been combing through the internet trying to find a mount. Can you share the slt file your friend used to create the mount?
I would love to order one
Here is the original doorbell holder I got on Amazon….
You really just need to metal clamp part so I’m not sure if there is a better way to get the clamp without the rest of the materials.
Anyways….
Then my friend made the doorbell backing which attached to the doorbell and bracket.
He can print the mount, but it is printed to fit the c clamp from the Amazon link. That is important to note!
Here is the .stl file link: Printables
Price would be $10 plus shipping.
Let me know!
[Mod Edit]: Combined 3 posts into single post, referral tag removed from referenced product link and fixed typos to prevent forum software from treating post as spam.
How can I go out ordering the mount?
How can I go about ordering the mount?
Since the user who posted this is not responding, and they posted the STL file, you may want to try a 3d printing service. Many let you upload your file and they will print and deliver the item.
Just a thought.
Checking just in case the one who posted about the 3D printer mount is responding to messages. Is there a way to order this?
Thank you!
Has anyone found one a security door? All the ones online are for doors that swing inward and nothing for those that swing outward (or security doors).
Hi I know I’m super late here, but currently looking for the same thing you were. I just learned that the Roku wire free doorbell is the EXACT same body size and everything, as the Wyze doorbell pro.. if that helps. Still looking around for a good mount for apartment door.
