DuoCam Doorbell Contact Screw Replacement
I am a dummy and dropped the two screws that go into the back of the DuoCam Doorbell that hold down the contact wires for power.
I contacted Wyze and their only solution was to warranty the entire doorbell, but I want to avoid being without a camera there for the days/weeks it will take to get a replacement…all for some screws.
I’ve already went to two hardware stores and wasn’t able to find anything that was the right size. I also saw a suggest of a M3 Philips pan head for an older model but they don’t sit flush on top.
Does anyone know where I can purchase some replacement screws, or have the dimensions of the screws? I’ve been rocking it battery only for a few months and I really want to be able to record 24/7.
Thanks for any help you can provide!
Welcome @JL925 ,
I can check on the size of the screws, possibly tomorrow.
However, I found these on Amazon, which may work as the screws are normally standard sizing:
or
