A month ago I purchased 2 Wyze window cams. One is installed on a south facing window, the other a north facing window. I also have 5 other Wyze cams (V2s and V3s) inside my home. They are all connected to an IOT VLAN on a Ubiquiti network. All the Wyze cams have SD cards installed and are on Cam Plus.
The other Wyze cams all stream continuously to my android phone without issue. However the 2 window cams pause/freeze the stream after a few seconds (usually 5-6 seconds). No error messages, the stream just stops/freezes. Both window cams stop at about the same time, sometimes one lasts a second or two longer.
If I disconnect and reconnect to the camera the stream runs again for a 5-6 seconds and then again freezes.
I understand that Wyze cameras try to hand off to a peer-to-peer connection between camera and phone after a few seconds, so thought my firewall might be blocking some communications between my trusted and IOT VLANs. I updated my firewall rules to allow through a number of connections between VLANs to enable this. All my other Wyze cameras (non-window cams) are working fine with the current firewall setup, it’s only the window cams that are “freezing” after a few seconds.
This happens regardless of whether my phone is on WiFi or cellular data. It also happens when playing back from the SD card.
Thought it might be a heat issue due to sun exposure, but my north facing and south facing window cameras both freeze after the same amount of time even though one gets sun exposure and one doesn’t. Ambient temperature is not particularly hot right now (low 20s C).
I tried changing the SD card as well in case that was the issue, but no effect. I’ve tried both Samsung PRO Endurance and PNY High Endurance cards.
The cameras are reporting good signal strength (RSSI: -49dBm for one, -42dBm for the other). The IOT network to which they are connected is 2.4GHz only.
Firmware is updated on both window cameras to 1.3.0.47.
Any ideas on what might be the issue with these Wyze window cams and what to do about it?
EDIT: I just checked and continuous streaming seems to work when the window cameras are viewed through the Wyze Web Portal. The above issues occur when viewing the cams on my android phone via the Wyze app (updated to latest version), which is my normal way of viewing them.
