Can someone help? I’m a newbie. I bought 3 wyze thermostats for my 3 level condo. I have 3 zones (HVAC guy said they all have to be set to cool or heat).
Here are the three zones
1: Main level
The main one should work, but the other 2 zones probably will not work like you expect them to. There’s likely not enough power to run a thermostat like the wyze from the zone control panel, let alone 2 of them. But without seeing the other side of the wiring (furnace or air handler or boiler or zone control panel), I can’t be sure.
