Will a 64 GB SD record more? How do I format it in either the camera or computer to make it work?
I put a 64 GB High endurance card in one of my cameras , I just put it in , formatted it through the app and it has been working fine ever since
Most of my 16 cameras have 64GB cards. Work fine and yes, they can hold more. I format in the camera if needed. The last four I bought did not need to be formatted.
Thank you. Which SD card (like brand) have you been using specifically?
And how do you format?
Thank you again.
As far as card type, a few are from Wyze (32GB), most are SanDisk 64GB Extended Duration
https://www.amazon.com/gp/product/B00V5Q1N1I/ref=ppx_yo_dt_b_asin_title_o03_s00?ie=UTF8&psc=1
To format in the camera, follow these steps:
Select that camera to view,
Click the gear icon in the upper right corner,
Select Advanced Settings,
Select Local Storage,
Select Format SD card (click the green “Format” to the right)
Confirm that you want to continue.
