Wifi signal indicator
The Wyze cam has a signal strength number under device info.
I have a v2 cams and the strength numbers change every 10 seconds when I check them. 99 then 80 then 58 and so on.
Ive had 26 percemt and the camera works, 86 percemt amd the camera can not connect.
Anybody else have this type of wifi movement?
Mine have been pretty consistent. One is at 82% and the other is at 97%. I haven’t had problems connecting to either while on the same network or remotely.
mine have been extremely consistent. I wonder if you don’t have some sort of interference coming from other devices in your home or possibly a neighbors
