Wifi options
Wifi options in case the Wifi doesn’t work. Let say the wifi have a problem and all of a sudden it disconnect Wyze camera should be able to reconnect to a different Wifi or other internet connection without taking out the camera from where it was placed.
If you would like to request that Wyze add this feature, that is handled thru a new topic post in the Wishlist. Go to the Wishlist, search the topics for one that matches your request. If you find one, vote for it at the top, like :heart: some posts, and add your reply post to support the request. If you do not find a match, submit a new topic for approval.
In your search, you may find that Allow Cams to automatically connect to multiple WiFi networks meets your request needs.
