Why is my video upside down?
I got my Wyze OG came about 3 weeks ago. At first it was fine and the video was coming in clearly and right side up. I was playiing with it trying to get it to turn, and think I broke something where the camera rotates on the little stick it is mounted on (that secures to the base) to the base (now its extremely hard to get it to point to where i want, which is another ordeal, the mount is not well made unfortunately). The video is now coming in upside down and I cannot seem to fix it…
Check your cam’s settings: Wyze app Home > your cam > Settings (gear icon upper right) > Advanced Settings > Rotate Image 180°
thank you!
No problem… glad to be of help. :+1:
