Why are entries not dated with time?
I have no idea how old the posts, subjects and or solutions are. Annoying
Welcome to the user-to-user forum, @knowaczark!
Are you talking about forum posts? If so, there is a date right across from your name. It starts out in relative time, and later moves to a date format. If you hover your cursor over it you can actually see the precise time.
There is a similar format when seeing a list of messages, although it you are viewing by ‘latest’, all of those will at least have pretty fresh responses. You have to go to the first post in the thread if you want to see when it started.
Does that help?
Thanks. In portrait I was not seeing the posted dates. Rotate to landscapes solved by issue. Duh me. Thanks again
