WHM went off and Noonlight called? How?
So I have been very confused about the Wyze sense hub “environment“ section. It says I can add sensors to be monitored, and when I add them to the monitored list I can then click on them and it brings me to the regular notification list for that temperature sensor. I do have it set to send me notifications when the temperature rises above 98°, which it does this just fine, but today noon light called me and my alarm was going off because of freezing temperatures. This was a false alarm but I’m wondering why this happened because yes it is in the monitored sensors list but the section where it says notify me when the temperature is below x, I had that turned off.
So my question is if you add a sensor to the monitor list what does that mean exactly and when will they call you? Like when the sensor is in what state? Because obviously those notification settings don’t seem to make a difference.
I can see this being very beneficial because you can add a leak sensor to the monitor list, but again I just want to try and make sense of when it will contact their service
