[Mod Note]: Edited post for embedded viewing in web browsers, fixed tags and title.
@noursaw, would you like to provide some context and a proper topic title? Otherwise, this kind of looks like spam.
Post edited. ![]()
Looks like a bug across lens or a poltergeist. ![]()
Thanks, I thought about just flagging it but thought it might be better for the user to take care of it instead of tasking Moderators with more work. ![]()
I agree that it looks like a .
I love the ghostly videos. Not as common and spookier than the orbs. ![]()
Flying balloon shadow.
Not ?
Just so we’re clear, I don’t believe in paranormal. I don’t think it is a bug on the lens as it appears transparent as the OP mentioned. More like something going across the light source above and behind the camera.
I don’t see the OP’s video as anything spooky. Could be anything floating close to the lens. My Wyze v3 front yard camera caught a clump of my Golden Retriever’s fur floating over my house from a backyard brushing in 2023.
My first impression was that it is a gaseous thing like smoke or a puff of black exhaust in the wind.
There is a small possibility that it could be some kind of swarm of small insects.
Any other kind of dust or debris. I have seen condensation look like this, though usually not black.
My primary guess would be a puff of smoke or exhaust.
Thank you! I was hoping someone would chime in as to what I’m seeing also. I’ve been a longtime user and have all Wyze cameras this one is V3. I’ve seen many strange videos but this one really stood out as strange. I went to my other cams and no wind was blowing around my house at the same timestamp.
Looks like a ballon with a string on it
One looks like the top of a dandelion blowing in the wind.
Proof of the paranormal right here.
@Antonius’s fart bubble. ![]()
What camera is this?
Picture super clear and what mount did you use to mount the camera?
Is it a wireless Wyze camera?
I think both videos posted are from the V3 cameras. Indoor/Outdoor plug in wifi cameras.
If you are asking about my clump of dog fur video, it is a Wyze regular Cam v3 mounted inside a double pane window. I made my own L bracket out of sheet metal attached to the inside window sill. The v3 is a wired camera plugged into power below the inside of the window.
I believe my wife would like you to know the blue masking tape is not visible once the blinds are closed.
You managed to have that contraption vetoed by your wife? She must really love you ![]()
