Webhooks on IFTTT to tinyCam with Wyze Pan Cams
Ok guys. Now my question is: Can I send webhook requests to tinyCam from IFTTT? I have been trying but it is not working.
I am trying to stop an start tinyCam (v12.0.2) background service on a phone (LG X212, Android (can’t remember the version)) when I am arriving home (stop service) and leaving home (start service). To trigger the events on IFTTT I am using Life360 and it seems to work firm BUT IFTTT keep reporting on Webhooks Activity this: Applet skipped, Unable to make web request. Your server returned a 401.
So, Life360 is triggering well the event but somehow webhook is failing. I know that “Your server returned a 401.” is related with authentication; so maybe the webhook authentication is failing…not shure what is going on whit it.
The webhooks I am sending trough IFTTT are these:
(Supouse this:
My tinyCam public IP: 1.1.1.1
My tinyCam public Port: 01)
To shutdown tinyCam background server:
URL: https://1.1.1.1:01/param.cgi?action=update&root.BackgroundMode=off&user=admin&pwd=mypassword
Method: GET
Content Type (optional): text/plain
Body(optional): (empty, I put nothing over here)
To start tinyCam background server:
URL: https://1.1.1.1:01/param.cgi?action=update&root.BackgroundMode=on&user=admin&pwd=mypassword
Method: GET
Maybe some of you guys can give an advice?
In theory that should work, but you’d probably get better advice from TinyCam support/forums.
Does TinyCam have documentation for its URL encoding for authentication? If you manually visit those URLs in your browser does it still ask for a password or does it trigger the actions? As you mention a 401 error is “unauthorized” which means the authentication failed.
Actually i found a solution. The proper format on the URL is: https://user:password@ip:port/rest_of_url_from_here/
With that format it works perfect.
