How do I remove my wyze camera from the weatherproof housing
Welcme to the Community Forum @thebinks33
Please elaborate, an enclosure from Amazon or the Wyze Outdoor Camera?
Usually the aftermarket enclosures have a removable rear panel and just slide out. You might have to slide a thin piece of metal between the little rubber foot pads and the case if they’ve broken down and stuck.
Solution or no?
