I thought I recalled a weather rated power plug coming later as an accessory for the v3 cam. I can’t seem to find it in the shop anymore or any reference to it. Is it still coming? Already released? Cancelled?
Does anyone have a recommendation for a weatherproof plug to power a v3 outside?
Note the transformer needs to be inside but you can make any custom length of cable to get it to camera outside
You can also buy a higher amperage power adapter and wire several cameras off cable run, make sure your larger amperage power supply has at least 0.8 Amps per camera available. (ie. 5 cameras = 12 volt 4 amp supply)
