I’ve Fat Fingered a lot of setting on my phone and one time it caused me to reset the entire phone. ![]()
Wish Wyze would kick around the idea of a new and much improved Pan Cam V4. 24 - 30 fps, higher resolution, better connectivity and enhanced night vision.
Not a developer, LPR can cross check with DMV as far as registration goes. Not sure about ViN 'ng a car, but it would be a good idea to know if the tag was coming back stolen or doesn’t match a vehicle description. Maybe put a report to authority of suspicious tag option, but that could trigger too many false reports.
You should’ve taken piano or guitar lessons, that would’ve kept your fingers thin![]()
My Fingers are only fat at the joints. ![]()
Thanks for asking. Not on my priority list.
Just like fat ankles, not very pretty ![]()
Yes, my car is parked in the drive and if I select vehicle on the smart detections, I get constant notifications. If only it would choose MOVING vehicles, then I could use that feature.
Yes, but I can’t block out the car because then I wouldn’t capture people walking up to it or along the side towards the house. I’d have blind spots that I don’t want.
Lol i set it off every day becuz my hand slips ![]()
Frrr bro like my camara will pick up a tree shadow and alert me ![]()
Yes, I like this Idea and Option. This option will work perfectly on the Wyzecam V4 since it has a crystal clear camera and zoom capability.
I love it when a bee or even a long legged mosquito flies by the camera, and it alert Alerts me, “pet detected” ![]()
Speaking of a Bee, here you go.
I get these false alarm clips all summer long!
They see the Camera, and think its a great place to make a nest,
until they figure out its not a hole ![]()
I’ve been using a Wyze contact sensor on my mailbox for years. Originally, I use the version 1, but since the version 2 came out with home monitoring, I’ve been using that one. My mailbox by the road is more than 80 feet away, and I have it so Alexa announces “The mail is here” when the box opens, along with a notification to my phone and Apple Watch. I have an extra large metal mailbox, so the contact sensor is on the outside in a 3d printed enclosure to keep it dry. It works great!
Do you have the 3d model for the waterpoof case? That’s an excellent project.
Although I do have a 3D printer, that particular outdoor cover I got from a member here. It’s a great cover because the sensor can be popped out for battery changes. I’m not affiliated with him and don’t know if it’s the same person, but this cover on Etsy is the exact cover I have, so it may be him. Outdoor Cover for Wyze Sense V2 - Etsy
I live out in the country, with a driveway that is more than 100’ long. I NEED to be able to see the license plates of the cars that approach my house.
… and being able to recognize known cars would be helpful as well.
Having one that can use regular AC power - where the electrical cable can be run through a wall to be plugged in INSIDE the house would also be a huge benefit.
