Can you use the mounting plate and tape as in V2 to mount the WCO? Does the wt of it require a screw?
The outdoor camera mount has screw holes on it so you can mount it with screws. The end of the mount connects to the camera with a magnet and you can connect it to the top or bottom of the camera.
The base is not magnetic, but you could use some 3M adhesive to mount it. I wouldn’t recommend doing that because the camera is heavy and that style of mounting won’t hold up to the elements well.
You can also use the tripod screw on the bottom of the camera to attach the WCO to any mount with a tripod screw. I’d recommend using this for locations with high wind or other things that may knock the camera down(this has happened to people).
