We are mounting a WCO on stucco, but the mounting screws don’t look long enough to secure it properly. Suggestions?
Did you use the anchors that came with the screws. Drill a small hole in the stucco, insert the anchor all the way in the hole, insert screw.
Welcome to the Wyze community @orion300jar!
The outdoor camera has a universal tripod screw on the bottom. You can use a universal security camera mount and your own stucco screws if @Antonius‘s method doesn’t work.
https://www.amazon.com/Security-Adjustable-Outdoor-Compatible-Dropcessories/dp/B06X6H8QDY/ref=sxin_9?ascsubtag=amzn1.osa.7126ec0e-49f4-4bce-9c55-12172447d027.ATVPDKIKX0DER.en_US&creativeASIN=B06X6H8QDY&cv_ct_cx=Arlo+mount&cv_ct_id=amzn1.osa.7126ec0e-49f4-4bce-9c55-12172447d027.ATVPDKIKX0DER.en_US&cv_ct_pg=search&cv_ct_we=asin&cv_ct_wn=osp-single-source-gl-ranking&dchild=1&keywords=Arlo+mount&linkCode=oas&pd_rd_i=B06X6H8QDY&pd_rd_r=c1aa0448-f579-4e21-b8ef-f3a66608fb36&pd_rd_w=tYPMV&pd_rd_wg=PVnIX&pf_rd_p=9d7390bd-9235-4046-b950-0331f14c437d&pf_rd_r=CHREAEZAFJR0XFSBS91A&qid=1608503815&sr=1-1-d9dc7690-f7e1-44eb-ad06-aebbef559a37&tag=aimassociatesbp-20
