Water in outdoor cam v2 its 2-3 years old
Warranty yes or no ?
All depends on when it was purchased and from where.
I would reach out to Wyze and discuss it with them. This is a user to user Forum and we cannot determine if something is under warranty or not.
Yea … just curious if others had water penetration on a camera that is specifically advertised for outdoor use in all kinds of weather ![]()
Yes, I have no less than 6 wco v1/v2 that have died due to water ingress. Most of mine have been at the rubber gasket. You can see green corrosion on the micro USB port.
Water getting in a Wyze Cam I am in Shock ![]()
Got over a dozen Wyze crap cams that water ruined…
Wyze, the disposable cam… Cause they don’t last to far beyond warranty… At least Bic lighters are labeled “Disposable” ![]()
When they die they get replaced with NON Wyze replacements ![]()
