My son-in-law gave me the kit he had installed at his house when he upgraded. The devices he included were the Wyze video doorbell (V1), the Wyze Chime, and the Wyze Doorbell Chime Controller. However he did not included the fuse wire.
The searches I’ve done seem to say that the Chime Controller is not compatible with the V1 Video Doorbell, so I’m not sure why he included that part. And I’m concerned that if I just bypass my existing chime with a straight wire, not only will there be no fuse, but that I would also be creating a dead short in the 24VDC circuit when the doorbell button is pushed as the load of the existing doorbell would have been bypassed. Does that fuse wire also have enough resistance to mimic the existing doorbell?
It does not, and I bet he gave you his extra parts (controller) when he installed his, I am assuming it’s a v2 doorbell?
The V1 doorbell does not use the legacy chime at all. When you install the fuse wire(if you had it), that process bypasses the chime and provides straight power to the doorbell location where you would install the V1 doorbell. The V1 doorbell uses the chime accessory that plugs into a nearby outlet to “chime” the house.
Here is an old post that takes about getting a fuse inline with the V1 doorbell
