Just sharing a brief piece of feedback that I used the corner mount and hooked the Wyze Video Doorbell Pro up to the existing power and really struggled to get the wires and wire nuts into the tiny crevice so that the doorbell would attach flush with the mount. If the mounting kit were a little deeper with some additional room, or had a wider gap/hole in the middle, it would have been easier. I’d be curious to know if others found this step easy or hard.
Related topics
Topic | Replies | Views | Activity | |
Wyze video doorbell hardware | 2 | 259 | November 14, 2021 | |
Horizontal Wedge for Video Doorbell Pro | 7 | 1238 | July 16, 2022 | |
Doorbell Pro Mount on Trim | 4 | 311 | March 29, 2023 | |
Wired Doorbell options? | 33 | 452 | April 15, 2025 | |
Wyze Doorbell Pro Backplate | 2 | 1369 | March 9, 2022 |
