Basic question: I am confused, does downloading new firmware update the Wyze app or just the camera?
I have noticed some of the screen pictures uploaded by forum members look much different than mine. i.e Notifications screen
Just the camera. The app is updated from Play Store or Apple Store.
I think it will vary a bit depending on which app version, phone OS version and which wyze devices you have.
That’s under (Android) Settings, Apps, Wyze, Notifications.
Android has a separate set of notification settings for each app that exists outside the app.
If you go to android settings, apps, scroll till you find wyze, notifications and click on the categories it opens up more settings.
If you click “wyze message” in your screenshot it should open up a sub menu with more settings as well.
Thanks, you were right. It wasn’t obvious to me that there was still one more page. Of course, now I wonder how many more hidden pages there are.
Same with mine, I had to click WyzeNormal to get to the sub sub sub menu. Between Android version differences, Wyze app version naming, phone implementations, and the Microsoft/Google disease of HIDING clickable and scrollable things, it’s a mess.
I only found the sub-menus because of a notification issue in the early days of the early access lock. There was also a persistent geofencing notification with the lock even with auto-unlock turned off which was annoying. One of the sub-menu options was able to get rid of the persistent notification.
