V4, possible to turn off motion detection with Modes?
Before I order one, is it possible for the Home mode to turn off motion detection for the V4 cam? It looks like it is not possible with the new Duo Doorbell. Even though you can turn off notifications I don’t want it to constantly detect our motion when at home,
Is this a question about the options available at the top of the Monitoring tab? I don’t use that section of the app much and haven’t ever subscribed to Home Monitoring Service, but I wonder if what you’re asking about is what’s being discussed in this Wishlist topic:
You can visit that topic to Vote above the initial post and share your ideas, questions, and use cases in the comments.
It looks like other users have asked the same thing in recent months without an answer from Wyze:
If you do not want Motion Detection when you are home, you could turn off the v4 within the App.
I have one v3 inside my garage. It is always plugged into the wall and I only turn the v3 on when nobody is home.
Thanks. I was referring to the monitoring tab Modes where the only option for the Duo Doorbell seems to be to mute notifications, not turn off motion detection. I guess I would have to have a separate automation for this.
That would be my guess, too, that you could probably do it with Shortcut Automations, but I agree that this seems like something Wyze should fix so you can have a one-and-done option from Monitoring if that’s what you’re already using for other Cams.
