This camera was operational for several weeks until one day it just randomly stopped working. I contacted Wyze for help who sent me instructions to follow. None of which helped. I tried contacting again but can’t get anyone to actually ready my email. I just get back the same or similar instructions.
I can’t seem to get to a factory reset. The purple light stays on. If I unplug it and plug it back in it goes red for 1 second and then to a sold purple light. I can not add the device to the set up process. The purple light is always on no matter what I do holding down the setup button does not change the light
These are instructions I received:
Troubleshooting Steps:
• Power cycle the camera first — unplug it from its power source, wait at least 30 seconds, then plug it back in. Give it 2–3 minutes to fully boot up. A solid purple light can indicate the camera is stuck mid-connection, and a fresh power cycle often clears it.
• Check your power supply — make sure you are using the original 5V/2A adapter that came with the camera. A lower-amperage adapter or a long USB extension cable can cause the camera to lose its connection or fail to boot properly.
• If the purple light persists after power cycling, perform a factory reset. With the camera powered on, press and hold the setup button on the bottom of the camera for 10–20 seconds until the status light changes and begins flashing red. Once it flashes red, set the camera up again as a new device in the Wyze app.
This is where I am stuck it will not factor reset!
• When re-adding the camera, connect it to your 2.4 GHz Wi-Fi network for the most stable setup experience. Your camera supports both 2.4 GHz and 5 GHz, but 2.4 GHz offers better range and wall penetration — especially helpful if the camera is not right next to your router. Make sure Bluetooth is enabled on your phone and the Wyzeapp has Bluetooth permission, and stay within 3 feet of the camera during setup.
• If you are using a mesh router system, try moving the camera closer to one of your router nodes during setup. Mesh systems can sometimes push the camera onto a weaker 5 GHz signal, which may cause connection instability.
