V3 turns on "Enable Hardware Decoder" automatically which stops Pan Cam touch controls
“Enable Hardware Decoder” is turned on anytime I view my v3 camera. When “Enable Hardware Decoder” is on, my Pan Cams no longer respond to the touch screen and the on screen controls cause the Pan Cams to cycle to the end stops. (No fine control.) Would appreciate anyone else verifying this. Happens on multiple versions of Android.
(I may have posted this in the wrong area so if a moderator thinks this would be better under a different topic, please move it. - Thanks
This appears to have been corrected with the most recent app update. (V2.16.23 for android)
