I have several V3 and V4 cameras running. Most are very dependable and stay online almost continuously. However, one of my V3‘s connects and runs for 3 to 5 minutes and loses connection. That happens to be close to the router and has a strong signal. Others of my cameras are way far away from the router, but stay connected with no problem. This seems to be a camera problem not a Wi-Fi problem. I have reset the camera several times and it works for a few minutes then drops offline. I have reset the camera several times and it works for a very short time then fails to stay connected. Any ideas?
What firmware is your problem v3 on?
Also, have you tried swapping power cables and power brick from a reliable working v3 to see if you have a power issue?
Good points. My firmware is up to date but I have not tried swapping the power cable and brick. Will try that tomorrow morning.
@StevenA
Well, you nailed it. This morning I switched out the power cable and brick. All is well now…Thanks, tlhutch4
