got the v3. get set up completed but app says can’t find device. doesn’t show up on app. help
Looking for clarification, so you set it up in the app, and now it doesn’t show in the home page device list? What app version are you using?
he cam itself was showing solid bue light connected. would not show in app and alexa says device not found. went into play store and app had an update notice. ran that and presto! every thing came up . sometimes just gotta keep digging
Its @Omgitstony magic! Glad the problem is solved
