V2 doorbell without existing doorbell?
Can you use the v2 doorbell without an existing doorbell? Got this for my mother for her birthday and didn’t know you needed an existing doorbell should I just get the pro since you don’t need a doorbell for that one? And return the v2 or is there away around having a doorbell installed as it’s a rental property and can’t really be installed… HELP!
Wyze’s Help Center article on the subject seems to answer your questions:
Do I need an in-house chime to use Wyze Video Doorbell v2?
Yes, you must have an existing mechanical chime.
Wyze Video Doorbell v2 uses its Wyze Doorbell Chime Controller to work with your existing chime. Even if your old chime is broken or not working, you can still use this doorbell and connect the chime controller!
However, if you don’t have a mechanical chime at all in your home, we suggest Wyze Video Doorbell Pro. It can be used wirelessly and relies on its included Bluetooth-enabled chime.
It seems like you’ve already arrived at the solution, since you asked about the Video Doorbell Pro in your original post.
