There were locations I wanted to mount some V2 cams that required the cam to swivel all the way around but it only rotates about 330 degrees. I found the stop tab and shaved it off with a razor blade. Problem solved. There are no wires attached to the base so I don’t see why it has a stop in the first place. Anyhow, before and after pics attached if you find yourself in the same boat.
Just a side effect of using others hardware design.
Very good craigs92040
It seems that the base had to be removed to have access to remove the swivel tab?
Do you have any intermediate photos?
Victor Maletic.
You are correct sir. It’s just two small philips screws and it pops right off. I didn’t think to take pics of that step.
Thank you.
