Using Wyze plugs to set up Alarm system
I’m setting an alarm system up using 3 wyze plugs. Can I give one command “Siren” on Alexa so they all respond at once?
Welcome to the Wyze community!
Yes, you can create an Alexa routine.
first make sure that you have the Alexa skill setup then go to Routines → new → when this happens → voice → set what you want to say(Alexa,”what you want to say) → then chose your Wyze plugs in the smart home section. You may have to chose the plugs individually.
https://support.wyzecam.com/hc/en-us/search/click?data=BAh7CjoHaWRsKwg0h6vTUwA6CXR5cGVJIgxhcnRpY2xlBjoGRVQ6CHVybEkiWGh0dHBzOi8vc3VwcG9ydC53eXplY2FtLmNvbS9oYy9lbi11cy9hcnRpY2xlcy8zNjAwMzM1MTk0MTItQW1hem9uLUFsZXhhLVNldHVwLUd1aWRlBjsHVDoOc2VhcmNoX2lkSSIpZmQzMmMzOTItMTBhOS00M2ZlLThkYTYtNjA5MDY3OWEzYjRjBjsHRjoJcmFua2kI--153ffb6c072816317958de7b58bd27aadba29087
Thanks @Brlepage , that’s a good Alexa page I hadn’t seen before.
Though I think it needs an update for the new Alexa PD announcements and routines.
There’s a separate one here:
https://support.wyzecam.com/hc/en-us/search/click?data=BAh7CjoHaWRsKwgAs4%2FUUwA6CXR5cGVJIgxhcnRpY2xlBjoGRVQ6CHVybEkiaGh0dHBzOi8vc3VwcG9ydC53eXplY2FtLmNvbS9oYy9lbi11cy9hcnRpY2xlcy8zNjAwNDg0NzI4MzItVXNlLVBlcnNvbi1EZXRlY3Rpb24td2l0aC1BbGV4YS1Sb3V0aW5lcwY7B1Q6DnNlYXJjaF9pZEkiKTBiZDhlOWY2LTRmYWMtNDNjYi05NWI1LTBiZDk3ZmVjNDQ5MAY7B0Y6CXJhbmtpBg%3D%3D--017228dc885d10eb67884968bb607006f856453e
Thanks. But what the heck. Those instructions are terrible. Turning on PD announcements under Devices, Cameras is much, much, much easier. It’s a single slider under Devices, Cameras.
