Enable Alexa Routine with Wyze Smart Plug
Hello,
I am able to setup Alexa routines with my Wyze smart bulbs, but I have not been able to figure out how to do it with my Wyze smart plugs. They show up in the Alexa device list, but when I go to create a routine, I can’t figure out how to select them. Is this possible?
Thanks,
Jon
Jon,
I was curious about your question. Sure enough, Alexa doesnt show the plugs as a trigger. It only shows the contacts / motions sensors.
I have multiple plugs and either use them through the wyze app directly or use IFTTT.
You can however use another type of trigger (sensor / voice / etc.) to turn on the plug.
Hope this helps out.
Jack
Plugs were at some point after the OP available as an Alexa routine trigger. Most recently, however, they have disappeared again. I’m investigating to see if I can find out what happened.
