Using Wyze climate sensor to control HVAC based on humidity?
So I currently have a Wyze Thermostat installed and one missing aspect is the similarly named ‘Overcool MAX to reduce humidity’ function on Ecobee. This basically ‘forces’ the HVAC to cool a set number of degrees beyond the set point in order to drop humidity levels.
Sometimes in Texas, air temps around this time can be around 72 but humidity levels can equally be around 75 indoors which just isn’t very comfortable at all. I’ve had to manually run our AC to get it to feel better. Is there a way to automate this function at all using the Wyze climate sensor which monitors both temps and humidity?
That was a promise that was never kept. I bought the climate sensors so I could remotely control the thermostat.
