Thermostat: furnace fan and climate sensor
I’ve got climate sensors that seem to work well and I use them to control a couple of Wyze power cords.
I’d like to buy a Wyze thermostat IF
  1. I can write a rule that will reference the humidity on one
    of my climate sensors AND
  2. turn just the furnace fan from auto to continuous depending on that
    humidity.
Does anyone have any experience with this?
You can’t do that at this time.
You can reference the climate sensor humidity as a trigger, but you can’t control the furnace fan via the thermostat. Here are the things you can currently control on the thermostat:
You might consider submitting something to the Wishlist:
Wow! Thanks for the definitive reply.
