Using Wyze app since 2019 and I'm going back to old version
I’ve been using the app DAILY since 2019.
Events tab. 1. Don’t need all those useless filters showing up first, I need my camera list showing up first. 2. Always have to hit “clear all” TWICE to actually clear all, waste of my time. 3. Order of cameras is not the same as my order in the Home tab.
Home tab. 1. Thumbnails don’t refresh. I had a thumbnail from 3 days earlier show up every day (even when I clicked and looked at the feed it would not refresh) when I had my camera in a different position.
Only good thing is the way notifications show on the notification drop down panel. That’s it
Can you clarify something as I am curious - related to the events tab:
What do you mean here? My event screen looks the same as it always has and the filters is an option to narrow your search. Do you have an image of what you are meaning or seeing?
If you clear all filters then the next time you go into the Events tab, it will remember what you had set and show you all events. Or are you talking about something else?
The Events tab is in Event Time order. Are you talking about the Filter screen and being able to filter on specific cameras? Those are in Alpha order.
In addition
Which version of the Android app are you currently using?
I can’t show you a screenshot because I’ve already deleted the new app and I’m using the old one . In the Events tab when I click FILTER the first items that show up to filter are the CAM PLUS event filters. In the old app the first thing that showed was the cameras. I have a dozen cameras only 1 has Cam plus. I’m more interested in seeing the events on certain cameras not trying to filter out if it’s a package or a cat or a car I want to just see the events.
If I filter the events to let’s say sound and three cameras when I leave the app and come back and I want to filter person and 2 different cameras I always have to hit clear all twice to clear the previous filters.
In the old app when you click filter the camera list with the check boxes is in the same order as in the home tab. The order on the new app when you click filter and you get the list of cameras with check boxes it’s not the same order as the home tab.
For the second item, you don’t need to clear first, you can scroll down and then check the cameras you would like to see and uncheck the ones you don’t. That apply the filter.
Have you checked or created a wishlist for the Filter option under events?
I have been using Wyze cameras since 2022. Back then it was App version 2.28. I am currently sticking with App version 2.50 as long as I can.
Yes I know I don’t need to clear first and I can go and uncheck which is what I’ve been doing. What is the point of having a button to clear all if I have to uncheck one by one? This new app has been out for months one would think these things I have mentioned would have been fixed by now but I’m not waiting just going back and using the old app as long as I can. Thanks for your help
