Wyze App no longer seeing any Events
Wyze App v3.1.0(564) is no longer seeing any Events for any day.
Can still see events if using browser. But Android App not showing any events for any camera. Can still see Live-Stream.
This just started happening in last few days. No changes to app or devices have been made recently. App is on 5G local wifi & cams on 4.2 local wifi, without any change.
Edit:; some cams have microSD cards, some don’t. No events from any cams.
Edit: App v2.50.9(512) does not have this issue on Android device
Check your Events filters. On the Events page, tap the funnel icon upper right > Clear All > Show Results.
I wonder if this is going to turn out to be another transient cloud issue, like what was described (or at least speculated) in another topic:
:man_shrugging:
My filters were reset on one of the updates, though I had the opposite problem, was seeing all events instead of just the ones I wanted, so the filter was removed.
@cargois42 try uninstalling and reinstalling the app. I’ve had to do that both for the 3.0 upgrade and the 3.1 one to fix strange issues. The upgrades don’t seem to be working right.
EDIT
@cargois42 NOTE - do not uninstall the app if you are still on the 2.X version. That likely means your device is not compatible with 3.x and you can no longer do a new install of 2.X!!
