I think the wake up sensitivity to the raised-hand movement should be user adjustable to cover different use and life situations.
The screen tap seems to be a nobrainer; I’m surprised it wasn’t implemented from the getgo.
I would like to have an option on the watch to disable raise to wake. This would be ideal for when you’re sleeping and move you hands , working out, or other times when you’re using your hands a lot and know you’re going to accidentally raise to wake the watch face.
This would be helpful so as to help conserve the battery life. A disable raise to wake icon on the watch would be good to have.
