Usb extension cable
can any usb extension cable be used to lengthen power cable?
should it be usb 2.0 or 3.0 ?
Looks like Wyze uses USB2-style connectors, so go with USB2 extenders. If you plan to run a long distance, consider heavier gauge wire if you get a choice.
