I had four alerts on my camera last night that started with about 6 seconds of silence, then you hear a click and there’s a huge flash of light. I have no idea what it is. Does anyone know what caused these flashes?
If your cam is pointed outside or is near a window, was there storms in the area/ or did you hear thunder? If not then maybe heat lightning(the kind of lightning you see but never here the thunder) although I don’t think it would be bright enough to trigger the ir cut filter. The click is most likely the ir cut filter but the flash idk what it could be.
Welcome to the forums! Do you have the event video you could post here so the group here can see? If you want we can get your forum trust upped so you can post the video.
