Unable to Login to Wyze Application with Opera GX
Hello,
When I open the Wyze App and select Get Started, it redirects me to a Wyze web portal, I am asked to enter my credentials. I successfully enter my credentials in the web portal ( WYZE - default login URL), and it appears to attempt to redirect me ( WYZE - Successful login URL) but it never redirects me using Opera GX. I click on Go Home, or hit refresh, the app never redirects back to the Wyze App.
I have tested the system using the Default Samsung browser and it does work correctly. I use Opera GX to synch all my information across all my platforms. It tends to be highly compatible across most 64-bit systems.
Manufacturer: Samsung
Make: Galaxy S26, SM-S942U
OS: One UI 8.5, v16, updated 09-01-2026
Wyze App Version: 3.24.0.1011
Installed Browsers: Default Browser (Samsung, v30.0.5.24) - Works, Opera GX (v3.3.14) - Default) - does not work.
Since it works with Samsung Internet, the simplest workaround is to switch the default browser to Samsung Internet just for the sign-in (Settings > Apps > Choose default apps > Browser app), log in to the Wyze app, then switch back to Opera GX. The app keeps you signed in after that, so you’d only need to repeat it if it ever logs you out. The step that fails is the browser handing the successful login back to the app, and some browsers just stay on that page instead.
