Unable to filter events by cam or group
Hello,
Has anyone noticed that the event filtering is completely broken in the android app?
Clips are there, but it’s no longer possible to refine the events list by individual camera or group.
@Mavens
Attached is how it has looked for the past couple of weeks…
What Android version and Wyze App version are you using? My Pixel 11 Pro is on Android 17 and I have Wyze App 3.26.0 (1046). I don’t use Groups but can select all five if my cameras.
Also, are you able to Live View and see Cloud Event videos for your cameras?
My events used to display like yours, but the feature is broken the past few weeks for me… per my screenshot above.
On my only Cam Pan v4, I have the events chooser within live view like yours. However, most of my cams are Cam Pan v2 and don’t have that available. I’ve always relied on the filter within Events along the bottom of the app.
My app version is the same as yours and my handset is a galaxy s26+… also Android v17 with OneUI v9.
Wyze user since 2019 and never had this issue before.
UPDATE-1: Before posting this topic, I had done a logout and cache clear to no avail. Just now, I removed the app, rebooted the phone, and reinstalled. Event filtering seems to be restored.
Hey @secondary_2g
I have noticed that with hit or miss inconsistency, What I found was that actually leaving it on the page or attempting to pull down to refresh the page solve the issue, kind of like it was taking longer than I wanted to load, but I only noticed it in places where I didn’t have great signal and mine was only on mobile connection. If I was on Wi-fi I did not have this happen.
Can you give us some more details such as as was asked above, The app version and possibly what device you’re using, and if it’s happening when you’re connected to Wi-fi or Mobile net. I think we can probably get this narrowed down and see what’s going on here.
Thanks @Bam ,
I think I’ve answered most of the technical details as far as app version, etc in my response above yours.
Regarding connection, this has been at my primary residence with good Wi-Fi saturation everywhere. Similarly, it did not work on carrier (verizon) wwan.
And it’s only been a recent phenomenon. I also tried pulling the screen down to see if it would refresh, etc, but it just didn’t want to cooperate.
Once I removed and reinstalled the app, it started working like normal.
Thanks for including this, because that was going to be my first question when I began reading this topic. FWIW…
This is how I tend to clear my Wyze app caches on Android (click/tap to expand):
  1. Clear the in-app cache: From the Wyze app’s home screen, navigate to  Account ➜ App Settings ➜ Cache File Size ➜ Clear.
  2. Swipe the Wyze app out of the running Android apps.
  3. Long-press on the Wyze app’s launcher icon (on the phone’s home screen or wherever you tap to initially open the app) and then tap  App info in the pop-up menu.
  4. Tap Force stop on the App info screen (may need to tap OK to confirm) and then tap Storage & cache.
  5. Tap  Clear cache on the Storage screen.
  6. Back up one screen (back to App info) and then tap  Open to re-launch the Wyze app.
Note: I don’t know what the options would be for modifying these steps on iOS since I don’t use that platform. If using iOS/iPadOS, you should be able to clear the in-app cache with Step 1, and that may help.
Sometimes I stop at just clearing the in-app cache, and often that’s sufficient, but occasionally I’ll clear the OS-level app cache, too.
Usually logging out and logging back in isn’t necessary, but if I’m going to force myself to do a new login anyway, then I will typically do a  Clear storage while I have the the Storage screen open in Android’s App info. Clearing that data has always forced me to log in again after re-launching the app.
Yeah, that’s pretty much the “nuclear option”: uninstall, reboot, reinstall, reboot, launch app, login, see if the issue has been resolved, etc. Glad to know this worked for you. Thanks for the update! :+1:
I’d also note that I’ve occasionally seen the Events Filters screen load improperly (doesn’t populate with the expected options), as @Bam mentioned. In my observation, it’s been an infrequent occurrence and will usually spontaneously resolve, but sometimes I try to “help” it along with an in-app cache clearing, as outlined above. Sometimes it feels like a server-side glitch when it still won’t load after a couple of tries. When it’s persisted as long as what you described, though, then definitely clearing your data the way you did (which removing the app should do) should be the definitive fix. Sometimes that’s what’s needed to resolve some other “stuck” app situations, as well, as has been discussed elsewhere here in the Forum.
