UI refresh - better grouping of devices
Suggestion - app needs to be able to separate smart device types on the initial device screen. Ie) bulbs, sensors, switches. I have many pages of devices and scrolling through the entire list every time is a PITA.
[Mod Note]: Your request was merged to this topic for better visibility in order for you to receive timely answers to your questions.
The Wyze app currently provides a grouping feature:
Grouping of Wyze Switches isn’t currently supported, but it’s in the works. Please vote on this feature here:
Do you mean an automatic form of grouping?
If so, I don’t feel that is much of a necessity for the app. On how many instances are you going to be adding a bulk of new devices? The manual grouping @Seapup mentioned seems like a good enough solution to this.
That’s it,
– Fishy
You can also sort the order of the devices so the most-used are at the top of the list, and the least-used are at the bottom of the list. :slight_smile:
