Turns off at 32 degrees (Correction)
When troubleshooting the camera I received info from Wyze that cold weather turns the camera off at 32 degrees. Living in Colorado I think this an important point! I believe it is important to accentuate the temp limits for people considering this Cam.
Correction: The email says the battery stops charging at 32 deg. So if u use up the battery before temps go above 32 it won’t work. Which is what happened to me.
Their info conflicts with the tech specs. Perhaps they meant to say -32°C? Mine was working fine at 8°F.
Ref: Wyze Solar Cam Pan Tech Specs
Same…these things don’t shut off when it’s cold.
