Turn off sections on light strip pro
With the lightstrip pro, you can change each section individually. If you could turn off sections the same way, that would be great for passing through an area you dont want lit. I am using them as under cabinet lights, and would like to pass behind the refrigerator without lighting it.
This is a great idea, both for passthrough situations like you suggested, or for people who don’t want to cut off the end of their lightstrip (in case they later move it and need the extra length, but don’t want it lighting up right now while it’s not being used in its’ current position).
This would be amazing !
It would be more flexible if they allowed for the setting of ‘relative’ intensity by segment (0-100%).
So if a segment is set for 50%, and the strip as a whole is set to 50%, that segment would illuminate at 25% of full intensity.
